I had one of these with an F2 fault i fitted a wash motor today as there was a split in the small hose, as i was testing it it was running along nicely then up pops a F7 fault, checking the fault codes its a problem with the flow meter, is this situated in the metering tank on the side, i was wondering if this may have been caused by placing machine on that side and water which leaked from the base may have soaked the terminals, i would grateful of any help with this one cheers Jj
