I had the f7 fault on this dishwasher and replaced the flow meter – still f7 appears on the pcb so i changed the pcb thinking there is a fault with it –
the new pcb when turned on its stuck on the rinse programme and the rinseaid led comes on- you cannot change the programme- you press start , the start led comes on steady, shut the door and instantly 3 short beeps followed by one long beep sounds….. open the door and random segments of the delay start window lights up. Turn it on and off and exactly the same thing happens. Does anyone have any ideas??? Does the new pcb need programming????? or setting up?????? if so how please????
