Diplomat ADP8332
  • #27677
    sharont1111
    Help….. Dishwasher not running properly, cleaned all filters and nozzles, checked pipes?
    Starts fine, after 20 seconds no noise (other than electric buzz) goes on for about 1/2 hour?
    Tried reset via some other help but doesn’t seem to work.
    Also, should both indicator lights be on constantly?
    #215168
    Re: Diplomat ADP8332
    Reset applies to SMEG-built machines only – yours is a Whirlpool.
    At the start of the programme, you should hear the drain pump running for a short time, it should then stop and you should hear the whoosh of water running into the machine, followed by the circulation pump starting. Would you please identify which one of these isn’t happening?
    sharont1111
    Unbelievably, its doing all three now BUT not washing very well (on a 65 wash)?
    #215170
    Dales-Electronic
    Does the water heat and does the detergent drop in the bottom
    #215171
    sharont1111
    Lots of heat but the tablet seems mostly in tact around the outer rim of the base?
    #215172
    Put it onto the rinse programme, wait for it to start circulating, stand back and open the door. You should see (briefly) plenty of water rising from the rotors. If you don’t, have a read of this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
