Diplomat ADP8332 – FA fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8332 – FA fault
  • #8713
    My Diplomat dishwaher is showing the fault FA. I understand that this may be a WI failure, but have no idea what this means. Can anyone explain this and if I can fix it without calling out an engineer?
    Steve
    #130125
    DentedPorsche
    Re: Diplomat ADP8332 – FA fault
    Hiya,
    The water indicator is only one possibility. Take the filter out and clean everything insight. Check that the base isn’t flooded. If neither of these works for you then I’d suggest an engineer.
    “FA. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling”.
    As you can see from the above it could be cabling or even the main board faulty.
    Hope this helps.
    DP
    Please, turn off the power before doing anything.
    #130126
    Thanks for the advice. Unfortuntely the fault is still occurring, so an engineer it is!
    Steve H
    #130127
    Not THE SteveH?
    From Pistyll? ❓
