Hello, have sought help from you guys beifre with success – so thought I would ask for your help again please – another simillar prob!
F2 code then FA – front off, panel down – drip tray full of water – mopped up and started cycle again and observing two “leaks” one from left and one from right side of white plastic circular area(seems to be ??base of sump) – left side appears to be result of slow overflowing on this side of area and right hand side appears to be coming from a small square ares of the plastic cylinder. Does this make any sense!!!????
Question is – any idea what causing this and is it a huge prob – prob need to call engineer but want to know if worth it –
its working again, but only matter of time til fills drip tray and realarms. Take it its not normal for this leak.
thanks in advance
sorry about amateur language – but have no idea of the correct technical terms
cheers
