Diplomat ADP8352 Draining Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8352 Draining Problem
  • #90747
    nubbin89
    I’ve just moved into a property where there is a 8352 washer. At first it worked fine but now after a few cycles it stops the current wash and beeps ten times. Also all 6 of the program lights flash continuously. It’s not draining any of the water out and when I remove the water from the bottom it will try to cycle again and stop with the same error.
    I’ve had a bit of a browse and haven’t been able to find any errors like this for my particular model.
    I did try to clean the filters out and there didn’t seem to be any food stuck in there, and I also poured boiling water into the bottom to try remove grease but no luck.
    If anyone has anything to suggest I would greatly appreciate!
    Cheers
    #445857
    Re: Diplomat ADP8352 Draining Problem
    All you can do is strip it down and investigate, see if there’s anything stuck in the pump.
