6 flashes means Water tap off / valve failure. I have found the most likely thing is a malfunction of the flowmeter (turbine) behind the left side panel. It is moulded into the air break so has to be renewed as one piece.
It pays to clean up and tighten the flowmeter connector plug and reed switch board connection first – fixed loads that way. 😉
