Diplomat ADP8502 – not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8502 – not heating
  • #22327
    Fixit2
    Diplomat ADP8502 will not heat water at any temp setting. Removed and tested heat module (25 ohms) and function tested OK. Supply from PCB side socket to heater 240v OK, I guess this means the thermostat is U/S? But confused as to why the the stat would be in the main power line, surely it should be to the PCB?? Is the t-stat the large plug-in insert on the drain, or the smaller one on the housing?? Any suggestions, thanks 💡
    #194494
    Re: Diplomat ADP8502 – not heating
    This is a Whirlpool-built machine. Temperature contol is via an NTC thermistor (the small probe in the sump) and electronic comparator array. The thermostat on the tube heater is a safety thermostat in case of an overheat situation. The large insert in the sump is a diaphragm switch and is the water level controller.
    Please don’t live test, it is rarely neccessary.
    DentedPorsche
    Did you get an error code during the cycle? or did it just wash right through without heating?
    DP
