Diplomat ADP8902 D/W
  • #90202
    rocker
    This dishwasher has smeg parts fitted. It has a strange fault, on starting up the pump runs for some while, then it appears to fill a small amount of water, then resorts to pumping, stops then pumps again. (its not a flooded base)
    There is a protruding piece of plastic around 2inch high, near filters like use to be in the Bosch D/W with a sliding magnet, but can’t see anything inside it. !!
    any advice would be welcome. Thanks John
    #444029
    Re: Diplomat ADP8902 D/W
    if i am right just before it stops is makes a faint beep
    change the power supply capacitor in the timer
    see my post and others here
    simple-pcb-repair-tips-t51155.html
    rocker
    Cheers Dave, I will check & replace if required. John
    #444031
    rocker wrote:This dishwasher has smeg parts fitted. It has a strange fault, on starting up the pump runs for some while, then it appears to fill a small amount of water, then resorts to pumping, stops then pumps again. (its not a flooded base)
    sounds pretty much as it should, proper fill starts after about 4 minutes of this.
