Diplomat ADP8902 – Water leak
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8902 – Water leak
  • #49171
    Shiaobai
    I have a problem with my dishwasher and am posting here in the hope that someone can point me in the right direction to fix it.
    When it is started up it fills with water but after a few minutes it comes out of a pipe at the bottom front left hand corner all over the floor.
    I have checked for any loose pipes and blockages but can’t find anything.
    The drain pump to be fine (I removed it and conected it to the mains and it runs fine).
    Has anyone come across this problem and know of a solution?
    Thanks in advance,
    Andrew
    #298962
    Re: Diplomat ADP8902 – Water leak
    The water level control is not working and the overflow pipes are running water into the base tray. The machine is made by SMEG and this is a particularly awkward one to solve. Blockage, pressure switch, computer are all possible and likely suspects.
    You really should get help to solve this one.
