Turn oven on by selecting 200C. Fan starts up and oven begins to heat up. After several minutes the whole oven shuts down. Several minutes later everything starts back up again. The cycle then repeats itself.
Is this a problem with the oven thermostat or is there a thermal switch fitted to this oven?
I have removed the switch and joined the two wires together (in effect bypassing the switch). The oven now heats up to 200C and maintains this temperature without the oven completely shutting down. This would seem to indicate a faulty thermal switch – just need to order a replacement.
As an aside can anyone explain how these thermal switches work?
