Diplomat AHY3610 electric oven RCD problem
Home Forums Public Support Forums Help And Support Diplomat AHY3610 electric oven RCD problem
  • #95580
    vikidob
    Hi, I bought second hand Diplomat electric oven model AHY3610. When put the oven on RCD going off. When disconnecting lower oven element oven working perfectly. I have checked the lower oven element visual looks evening ok, when was check with Om meter showed 0.56 Can you help me with any suggestions, please.
    #460825
    if it works when you disconnect element its likely that element has an earth fault
