diplomat ahy44**
  • #19958
    eng14
    awkward fault with this cooker and need advice.food only cooking on one side,when fan oven selected,burnt while uncooked on other.im baffled only used to get this with side element cookers,changed main oven stat no difference.also any idea for m/o stat part no and element part no and who supplies,thanks all richard,need help awkward customer. 😕
    #185180
    Alanj
    Re: diplomat ahy44**
    Hi eng 14,
    does this fan oven work with a circular element or just a conventional oven with a fan. If the food is only cooking on one side I would suspect that one of the elements has gone, top or bottom.
    Alanj
    #185181
    Dave_Conway
    AHY44** will have two more numbers on the end (hence the asterisks), those are taken from the user manual and not the oven rating plate 😉
    Probably a door seal or hinge issue though 🙂
    #185182
    eng14
    thanks for the reply guys,this oven has circular element alanj,dave i like your prognosis.i took this mod no from user manual,any idea what p/nos hinges and sel are likely to be,thanks richard.
    #185183
    gegsy
    eng14 wrote:dave i like your prognosis.i took this mod no from user manual,any idea what p/nos hinges and sel are likely to be,thanks richard.
    Yes when you supply the full model number off the appliance like Dave has requested 😉
    funkyboogy
    sorry for late reply, got a mate who works with diplo,
    he says its the fan elelment thats faulty….
    hes had a few like this…..
    still hasnt worked out the reason for the prob though …
    cheers
