Diplomat AHY4410 Integrated Oven Grill Problem/s
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat AHY4410 Integrated Oven Grill Problem/s
  • #77007
    jontymox
    Good afternoon all,
    As an inexperienced oven engineer, I wonder if anyone can assist with a problem relating to the above grill fault?
    I have renewed the twin grill element, as the outer section had failed.
    However, I cannot get the inner section to work as their is no power being supplied to it.
    Having had a look at the switch assemblies, I would appreciate it if someone can let me know if their is a regulator that may be faulty?
    If so, whereabouts is it located in order for me to test its function?
    Thank you in anticipation.
    jonty
    #400384
    Andy jones
    Re: Diplomat AHY4410 Integrated Oven Grill Problem/s
    Was the inner section working before you fitted the new one
    #400385
    jontymox
    Good afternoon Andy,
    I don’t think either were working.
    The customer said the grill had been working “below par” for several weeks.
    I should have checked rather than hoping new element would solve problem/s completely!
    Jon
    #400386
    SAMURI
    The outer section is for the oven, the inner section is for the grill.
    The inner section will only work with the door open.
    Did you have the door open to test.
    Bob
    #400387
    jontymox
    Hello Bob,
    Yes, the door was open when checking element operation.
    You have raised a very good point regarding the function of the inner and outer element sections.
    There was/is some confusion over the control switch operations, due to the customer being unsure, and no handbook available.
    I will return and make sure we are actually setting the controls correctly, although did try them in several positions.
    I’m beginning to suspect the switch, and will carry out further tests, unless you know of any other possible cause.
    Many thanks,
    jonty
    #400388
    SAMURI
    It may be the thermal cut out for the Grill open circuit.
    Bob
    #400389
    jontymox
    Good morning,
    I’ve ascertained that there are two thermal cut outs – one pre set @ 48 degrees, the other 180 degrees.
    Can I assume the lower temp’ cut out is used for the grill?
    Best wishes,
    jonty
    #400390
    SAMURI
    Yes it should be the 48 degree cut out stat for the Grill but you can double check as it is normally marked on the stat
    Bob
    #400391
    jontymox
    Thanks again Bob,
    Will let you know if TOC was cause next week.
    Hope you have a good weekend.
    jonty
    #400392
    jontymox
    Good evening,
    Have fitted the above TOC this afternoon, yet fault remains.
    However, the new TOC is giving an infinity Ohms resistance reading on my multimeter, as is the original.
    I expect a 0.2 to 0.4 reading usually, so wondering if new part is faulty?
    Any thoughts?
    jonty
    #400393
    Criscold
    I don’t think your problem is associated with the TOC, Do you get the neon on when the grill is turned on and also is the timer working ? According to the drawing the 48 stat is for the cooling fan and you should have 2 x 180 stats, one for each oven.
    PM you email address
    Colin
    #400394
    jontymox
    Good morning,
    My email address: jon.mox@virgin.net
