diplomat amp552
  • #43521
    bluejack
    set programe on this machine it fills then starts to turn the drum but then stops for a few seconds then trys to move again and again trying to turn but not moving more than an inch , bushes are ok ,checked the board looks ok ,loom seems ok , the other thing is i removed the board to check it but the connectors are not keyed so could do with a wiring diagram, thanks.
    #277542
    Re: diplomat amp552
    If it’s a Servis then you may find the wires to the connectors are labelled A,B,C etc. and this relates to CNA, CNB, CNC on board. As for the fault, there’s not much you can do but try in parts. Cheapest route is probably recon board from EMW first and send it back if no joy.
    Mike.
    #277543
    bluejack
    Re: diplomat amp552
    hi,thanks for advice looks like thats the way to go ,bluejack.
