Diplomat APL 3201 1x Help Element Issue
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat APL 3201 1x Help Element Issue
  • #42339
    rickkky
    Hi All,
    I think the element has gone on my Diplomat APL 3201 1x
    i.e. everything works (fan/grill) etc but no heat from the oven.
    On this model is it easy to change the Element, i.e. with out removing the oven it self out of the cupboard.
    Also what part is best that I replace it.
    I have taken the fan cover off but not sure what i need to unscrew or replace next?
    Any advice would be appreciated.
    Many Thanks Richard.
    #273165
    Re: Diplomat APL 3201 1x Help Element Issue
    Hi Richard,
    There appears to be several versions of this oven from what I can see, which isn’t a help I know. 😕
    As far as I know you can get it from the front but I can’t be entirely sure of that.
    HTH
    rickkky
    Sorry forget to give an update..
    Managed to remove the element am impressed with my self! (sorry i meant the Oven Element)
    Which oven element should i go for?
    Cheers
    Richard.
    #273167
    Hi Richard,
    The fan oven element is an easy one, it’s this element for the APL3201. 🙂
    HTH
    rickkky
    Many Thanks for your help, have just placed the order for the part.
    Cheers again
    Richard.
    #273169
    rickkky
    Forgot to say, received that Friday, working by Saturday, many thanks for your assistance…
    Last quick question thou 😳 how do you change the bulb, im not sure how to remove the glass cover without the feeling im going to break it in my hand…. any advice so i don’t break the glass cover to get to the bulb!
    #273170
    rickkky
    could any one help out my last question?
    Cheers
    Richard.
    #273171
    If it’s a round cover, you unscrew it. If it’s a square cover you flip it with a screwdriver form one end.
