Diplomat APL 3301 Oven (MFI) – Manual Needed – Removing Door
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat APL 3301 Oven (MFI) – Manual Needed – Removing Door
  • #93300
    happyman
    A family member has a Diplomat APL 3301 1X (Type B12) oven that the door has come off. There is no apparent damage to the door, but I cannot see how to get it back on.
    Does anyone know where I can find an instruction manual for this model of oven. I know it is probably around 20 years old now. I believe it was originally from MFI.
    Thanks in advance,
    Daniel
    #453838
    Re: Diplomat APL 3301 Oven (MFI) – Manual Needed – Removing
    Even before MFI went bust in 2008 you would have had little or no chance of getting an ‘instruction’ manual but that wouldn’t have been any use to you.
    A ‘service’ manual probably never even existed as all the MFI appliances where bought in from several different manufacturers.
    If you post a few pictures of the door and hinges etc someone may have an idea.
    #453839
    as iadom says post a picture of the hinge on the bottom of the door
    I think I know which one you have
    if the door has fallen off the hinges will be unlocked. to be able to put the door back the hinge has to be operated with pliers and locked. the picture will make it easier to explain
