Hi everyone
This is the last ditch attempt before we buy a new machine.
The problem is simple after the initial pumping out at the start of a program no water comes through. I’ve cleaned the filters at the mains connection and also at the solenoid end. I’ve checked the microswitch and float in the water matrix on the left side and the anti-flood switch in the base. No obvious blockages and the machine was recently cleaned.
Any suggestions?
Kind regards
Peter 🙂
