DIPLOMAT APM6724 REFRIGERATOR
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum DIPLOMAT APM6724 REFRIGERATOR
  • #45252
    Charmad
    Dear All,
    I have a Diplomat APM 6724 fridge which as recently developed a fault.
    The thermostat is set to 7 which is the highest level, but the fridge is not keeping the items within he fridge cold. The lights within the fridge are on but milk etc only keeps for a couple of days.
    Could you please advise me of what the problem might be?
    I look forward to hearing from you
    #285029
    cockney steve
    Re: DIPLOMAT APM6724 REFRIGERATOR
    I think that Diplomat is a brand of the now-defunct MFI.
    Please take on board that i’m NOT a professional Whitegoods engineer 😆
    If this is a built-in fridge, the door-hinges wear/break , the door doesn’t seal properly, the light can stay on, thereby heating the interior as fast as the compressor is trying to cool it.
    Again, instead of the big, black ,louvered plate at the back (the condenser) it’s quite common to have a small “radiator” hidden underneath with a fan…..
    these units suffer fan-failure and choking-up with fluff.
    you need to check if the compressor is actually cycling on-off…if it’s working continuously, either you have compressor valvefailure/gas loss OR, if the “cold bit” is actually getting cold, that would point to the excess fluff/cooling fan failure.
    In any event, it doesn’t hurt to clean the fan/fluff etc.
    You didn’t say if the thermostat is actually allowing the compressor to run.
    No compressor = no cooling.
    OK before I get shot down, there are ABSORBTION fridges and also PELTIER-EFFECT (cold-boxes for sure, but is anyone making a Peltier ‘Fridge???
    or, come to that, absorbtion, other than for caravans/boats?
