Diplomat APM6855-1
  • #89488
    Sunningdale
    Hello, I am a lady with no technical help available. My fridge/freezer (see above) is not working properly. The fridge temperature is showing at “H” whatever that means and the freezer says -20 however a lot of the contents are not freezing. I want to replace it rather than pfaff about with repair. Can someone tell me if the Beko BC50F is compatible with the Diplomat. The unit is integral and I read on another site that someone have the Diplomat integrally fitted and replaced it happily with the Beko. Your comments would be very much appreciated. Thank you
    #441530
    SAMURI
    Re: Diplomat APM6855-1
    The Diplomat is better.
    Empty the fridge and freezer, turn it off and leave the doors open for 48 hours / 2 Days.
    When you turn it back on after 4 to 6 hours it will work ok again.
    If the problem returns after 6 to 8 weeks it will need a new defrost sensor.
    If it does not work ok after the 4 to 6 hours the fan will be the fault.
    It is well worth trying to keep the Diplomat if you are looking to replace it I would go for a GORENJE.
    Bob
