Diplomat APM6855-1 No supply to fan
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat APM6855-1 No supply to fan
  • #53462
    nospin
    Hi, All i have found is that their is no supply to fan motor in freezer. I have tested all sensors in freezer and defrost heater and all ok. Is this a fault with the control board please?
    #316087
    funkyboogy
    Re: Diplomat APM6855-1 No supply to fan
    did you put align magnet up to mag switch in freezer lining as fan wont run unless frz door shut ??
    ally
    #316088
    nospin
    I did yes and the fan moved very slightly and then nothing. I took the door sensor out and i had 240v on each side of resistor. Could this be a faulty door sensor?
