Diplomat APM8512
  • #50813
    pudandtick
    Hi Wondering if anyone has some advice. I have a Diplomat APM8512 washing machine. Recently it stopped spinning the clothes and they come out soaking wet. I took the clothes out and tried to spin the machine the drum goes round but is not spinning quickly.I replaced the module and tested it when it was empty and it worked it was spinning fast i then put in a little amount of clothes and the same problem ocurred it wont spin. Any advice is much appreciated.
    #306054
    Re: Diplomat APM8512
    Ensure that you have plenty of belt tension, then try with a full load. The out of balance system is notoriously sensitive on these machines.
    pudandtick
    Penguin45 wrote:Ensure that you have plenty of belt tension, then try with a full load. The out of balance system is notoriously sensitive on these machines.
    Penguin45.Tks Ill try this
