Re: diplomat apm8522 thermostat
Take the thermostat out and look carefully at the tags. The plastic edge that surrounds them has number markings on it; either numbers or ‘pips’ on the plastic edge. 1 pip, 2 pips and so on…..not obvious, but they are there. The wires have numbers on them, so it should be straightforward.
If the machine is not spinning, check the heater for an earth problem – common cause of no spin on these Servis / Antonio Merloni offerings.
HTH,
Steve.
