diplomat apm8702
  • #14304
    josh9992000
    hi can someone tell me if you can use the dryer at any time on this unit or does it only work after a wash cycle if so how i have tried the half load button and timer but clothes still wet its brand new and i lost manual help please our lass is going mental? well if she can go any more mental that is
    #158936
    Re: diplomat apm8702
    Yes you can use the dryer on its own. Dont overload it though-about half a full wash cycle. Set the wash programme selector to the dry cycle position immediatly after the main wash spin. I think its marked as a grey dot on this model, then set the dry time using the timer knob, press the half load button and switch on. the drum should start turning back and forth and you should be able to hear the whine of the fan motor too, ensure the cold water supply is turned on.
