Diplomat APM8702/3
  • #44961
    euro
    Got this machine, fault is a knocking noise when on long final spin, have checked everything is tight enough, it sounded at first like loose weight but there ok, also checked heater just incase it was loose and hitting drum but again ok. The only other thing i can think it may be is a broken leg on spider, any other ideas guys
    Thank You
    Andy
    #283106
    spimps
    Re: Diplomat APM8702/3
    Check the fulcrum pins that hold the suspension legs top and bottom,wear can make them noisey.
    #283107
    Jonah
    Possible broken spider on inner drum 🙁
