Re: diplomat apm8702 not washing properly
loose belt?
motor-brushes badly worn….won’t pass current required to turn loaded motor?
poor contacts on board-connector,= high resistance-effectively the same as above.
We are assuming here , that your description means
” the machine agitates normally when unladen-that is, it revolves, stops ,reverses,…repeat till it pumps out and spins. when i load it, it won’t agitate but will spin”
my guesses …brushes ….or an outside chance that motor windings/board connections are faulty.
