Diplomat APM8722
  • #23834
    scots
    Hi hope someone can help.. have the above washerdryer the initial fault I have seen many times, the board situated on the RHS base had the connections and board melted due to the poor connections. I put a new board in with individual spade connections. Now I have the display showing that the prog has started door interlock energisies but machine doesn’t start. The display shows as if it has started.
    I am careful with rermaking the connections but wondered if anyone has a diagram to double check.
    Brian
    #199525
    Re: Diplomat APM8722
    Have got a service manual for that 😆 ……no wiring diagram in it though 😥
    Most of those i do are under warranty and i fit all the boards and motor, usually work after that.
    pm me your email address if you are interested.
    #199526
    scots
    Cheers Mark, anything will help..wished I’d never started on it, but then It looked very obvious.
    Cheers Brian
    brian@maglin.co.uk
