Diplomat APP 2310
  • #42363
    Cocko
    Back again for information this time on a cooker hood which has switches for the fans and the lights, it seems the switch for the lights is no longer working so I need to replace either the switch which is soldered on or the whole card. Last time I wanted info I was informed my Diplomat dish washer was in fact a Smeg, is this the same for my cooker hood. Whatever the case where can I get a spare and what should I ask for.
    Hope you can help as much as you did last time, so thanks once again.
    #273283
    Re: Diplomat APP 2310
    Switch assembly is p/no 12803292271. spares@ukwhitegoods.co.uk should be able to source it for you. Bear in mind that with the collapse of MFI there may be a few hiccups in the supply chain.
