Diplomat cooker ADP5324 oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat cooker ADP5324 oven
  • #60241
    Ryall
    I have a Diplomat Cooker.
    Type ADP5324. Model No.050565064. Serial No.10807212.
    The oven On/Off temperature control switch is not shutting the oven off completely & the red light is staying on. I am being told this switch has been modified. The modification involves changing thermostat & switch on both oven & grill plus the wiring loom. Is this correct?
    #341327
    johnmac11
    Re: Diplomat cooker ADP5324 oven
    yes that is correct, you have to change both stats, both switches and rewire them to get this to work, not a DIY job so I would suggest getting someone in to do it.
    Click the “find an engineer button” below to see if there is someone local to you that will take this job on.
    John
    #341328
    Ryall
    Thank you John.
    You have confirmed what the seller of this kit is telling me. I have a son-law who is an electrician. I’m hoping he will help me out with this.
    Kind Regards
    Ron
