diplomat d/w
  • #29985
    cornflakes
    model ADP 8224
    error E7 showing
    hand filled with water,,start prog.. unit empties although the first stage of drain is a little weak, then it goes into full flow.
    drain pump continues to run after emptying
    no water intake
    then after 2-3 mins E7 kicks in
    have not removed unit as it is tiled in with new ceramic flooring..who are these saddo’s who think you can encase appliances to save a few bob, for someone else to try and remove when they are far gone.
    I am aware E7 is timing out, but is it a drain pump problem or something else.
    many thanks
    graham
    Leicestershire
    #225420
    clivejameson
    Re: diplomat d/w
    Hi Graham, have a search for Smeg error stuff….loads about. E7 is drain time out but could be similar to E2 which is well posted. Filling by hand and then running may possibly give faults anyway.
    Basically, if the pump/pumping is ok, pressure switch ok and the transfer tube and matrix spotless….ohh and the dispenser solenoid ok the it’ll be the pcb…probably 😕
    #225421
    Re: diplomat d/w
    You can remove the pump easily with the machine is situ. E7 is an unusual error on that model, while its a common failure on the 5 button version.
