If you set this dishwasher on a cycle it it starts to fill then stops and the drain pump kicks in for a few seconds and then it starts to fill again.
It never pumps and fills at the same time.
This pump and fill action last for about 5 mins before it cuts out.
When you open the door, lights 1&5 are on (not flashing) if you turn the machine off and back on again lights 4&5 flash.
There is a slight leak on the R/H side looking from the front (looks like some sort of air break tank?).
The leak is so slight that there is no water anywhere near the anti flood device and the pressurized bladder does not inflate.
So totally confused 😕 dont normally touch these but it is the next door neighbours M/C.
Can anyone help please?
normally blockage in bottom of air break or rubber flap in sump stuck or the biggest black hose from sump to air break blocked with gunge, try cleaning out this hose from inside the sump with a plastic tie, the hose elbows to the right over to the air break. If its not that then looks like pcb assuming that the isulation value is good as a low insulation value on these will cause wierd displays on pcb
Thanks for your help Martin.Will have another look.
If it is a blockage I cannot see how the machine is sensing this and bringing in the drain pump 😕
