Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Diplomat d/w ADP8322
- This topic has 13 replies, 7 voices, and was last updated 16 years, 11 months ago by
Jazzmeister.
April 26, 2009 at 3:53 pm #45241
Jazzmeister
Participanthi could someone tell me if i am going in the right direction…
the dishwasher starts by pumpming,then starts to fil for about 10 seconds…beeps then starts to fill and drain at the same time…have tried the flow switch and motor and heater and stat seem to read out!
Last ditch i have ordered the rather expensive board…is there anything else i should be looking for? 😕Thanks Jazz! 😀
April 26, 2009 at 4:58 pm #284979clivejameson
ParticipantRe: Diplomat d/w ADP8322
Do you get any flashing lights and if so how many flashes?
April 26, 2009 at 5:20 pm #284980Jazzmeister
the 1st led on the left hand side..think it is the rinse stays on but does not flash and you cannot do anything unless you reset the programme!
April 26, 2009 at 5:29 pm #284981clivejameson
The ADP8322 is a Whirlpool made machine which should give fault code readings via the start light flashing so it looks like the pcb may have let go but there are numerous other known problems that can happen with these such as faulty flow-meter or it’s contacts, blocked level diaphragm sensor, faulty NTC (despite giving correct meter readings).
Do a search on ‘ADP8322’…there’s plenty to read 😉HTH?
April 26, 2009 at 5:40 pm #284982Jazzmeister
Thanx for your help!
May 1, 2009 at 5:48 pm #284983Jonah
HI Jason its probably the pressure switch gunked up, it twist fits into the side of the sump on right side behind the heater
May 2, 2009 at 9:38 am #284984Jazzmeister
ok this is ongoing now! 😕
I replaced the board and the fault returned although now i have the start light flashing 7 times..so at least i have a fault.As far as i am aware this points to the flow switch..please correct me if i am wrong!
i have replaced the flow pressure switch to no avail.Appliance still drains…starts to fill for approx 10 seconds then the fills and pumps at the same time and beeps…..Anymore advice anyone PLEASE!!! :rolls:
Jazz
May 2, 2009 at 10:39 am #284985funkyboogy
do you mean pressure switch thats situated at sump , or the flow meter that sits @ water tank …
ally
May 5, 2009 at 6:50 pm #284986suedehead1
apologies for jumping on to this post but i also have an adp8322 which flashes 7 lights the fault code guide says flow meter failure but it doesnt appear to have one it has the black grid pressure switch in the sump would that give the same fault code or have i missed the flow meter.
May 5, 2009 at 6:56 pm #284987clivejameson
The flow-meter is situated near the base on the LHS looking from front. It’s an integral part of the metering tank consisting of a small vane ‘propellor’ with a magnet attached to it. Clipped to the outside is a reed switch which ‘pulses’ open and closed as the magnet on the propellor rotates past it.
It’s a common fault for the connections to corrode or work lose 😉
May 5, 2009 at 7:08 pm #284988adv
diplmat dw wat a pain in the a..ss 😳
May 6, 2009 at 12:20 am #284989Penguin45
Nope, not true. Various manufacturers – SMEG, Brandt and Whirlpool mostly, then the unfortunate Haier episode. All have their little quirks, all well documented on here, all highly repairable. By and large built-in, so added value to the customer and a higher chance of a repair charge being accepted.
May 6, 2009 at 5:11 pm #284990clivejameson
Penguin45 wrote:Nope, not true. Various manufacturers – SMEG, Brandt and Whirlpool mostly, then the unfortunate Haier episode. All have their little quirks, all well documented on here, all highly repairable. By and large built-in, so added value to the customer and a higher chance of a repair charge being accepted.
We love ’em 😆
May 9, 2009 at 9:51 am #284991Jazzmeister
Thanks for your help guys…turned out it was the AIR BREAK ASSY which includes the little board(mentioned above)!
All done and all working great..thanks again!Jazz
