Diplomat D/W ADP8332 fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat D/W ADP8332 fault code
  • #42605
    Mark1
    ADP 8332 D/W Fault code FA11
    Been to looked at this dishwasher with this error code. I remove the code ie switch off power etc. As soon as it starts its programme the drain pump activates as norm and within a few seconds it beeps at me and shows this code. I’ve looked in the ‘Known Error Codes’ but failed to find one. The machine is 5yrs old. Hope you can help.
    #274117
    Jonah
    Re: Diplomat D/W ADP8332 fault code
    Check the pressure switch probably blocked up, or if waste hose is in normal u bend waste pipe check its not syphoning when filling
