hi all, been looking thro the search facility and cant find fault code or how to reset this machine ❓ the fault is the 4th+5th lights(from left) are flashing. any help would be appreciated 😛
Sometimes the board will go on to this sequence after previously displaying another fault code. If you find this, run the machine again and when it stops you should get the proper fault code; you’ll probably end up with 1,2 & 3 flashing & 5 on (E7). This will normally just be a reset job as P45 described above.
