Can anyone supply the part numbers for the following please?
Diplomat ADP8112…the rubber ring that fits around the end of the top arm feed tube (half way up the inside at the back) and also the plastic moulding that mates with it (back end of tube under the top basket)
Diplomat ADP8332 (Smeg???) The top feed tube that runs from the filter area to the top basket, and the moulding it clips into behind the lower arm feed tube.
754130918 is the rectangle shaped rubber ring
754130997 is called the upper spray gasket
761810109 is the plastic duct that mates up to it.
All smeg numbers by the way
