Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › diplomat dishwasher
- This topic has 3 replies, 3 voices, and was last updated 18 years, 6 months ago by
superspin.
September 19, 2007 at 1:22 pm #30659
superspin
Participanthi all
have a fault with this diswasher, turn on select programme,machine drains then fills and continues to do this for about a minute the the pump stops and contiues to fill for 30 seconds then bleeps and LEDS 123 all flash together. have checked flood switch,wiring harness,matrix and all pipes for blockedges, is this a possible controll board replacment .any help with this would be appreciated
model is diplomat ADP 8242 NR 10930 0602
September 19, 2007 at 1:33 pm #227986NWAR
ModeratorRe: diplomat dishwasher
Before you go for a new board give this a try first:
NWAR wrote:Sounds like the PCB needs to be reset:
With the door open switch the machine on using the door power button.
Press the program button 4 times within the first 3 seconds of the machine powering up.
At this point you should have both the first and last lights flashing and the middle three should be off – if not start over until you get this sequence.
Once you get the two outside lights flashing press the program button one more time and you will now be left with just one of the lights flashing.
Switch off the machine using the door power button but do not close the door.
Wait a few seconds (10-15 is plenty) then switch the machine back on and set it to a program to test.Hopefully that should do the trick.
September 19, 2007 at 1:34 pm #227987eastlmark
sounds like a good old E7 error, just needs re setting:
With the door open, turn on the appliance and within three seconds push 4 times on the program selection
button – The test program has been selected if the SOAK and STRONG LED’s are flashing
This LED combination represents the test program for the appliances that have a flow meter.
If the above indication is not shown on the appliance, switch the appliance off and try the sequence again
until the above LED’s are shown on display.
Now push on the program button once more to select the version ‘without flow meter’, check that the SOAK
LED goes out, and the display is indicated as below.
Do not close the appliance door, to complete settings switch the appliance off.
Now switch the appliance ‘on’ and test on a SOAK program.September 19, 2007 at 4:57 pm #227988superspin
ParticipantRe: diplomat dishwasher
thans both for that info will try to reset tommorow
