Diplomat dishwasher
  • #6222
    😕 i have just moved house to find an integral diplomat dishwasher without instruction that is moaning at me with code E7 could anyone help to let me know what this means?
    i would really appreciate this.
    Eve
    #116392
    Dave_Conway
    Re: Diplomat dishwasher
    The model number would be usefull but we will assume you have the version with 5 led’s on the display. It may work by resetting the control unit like this:
    Open the door, switch the dishwasher on by the on/off switch, within 3 seconds push the programme select button 4 times. The two outer lights should now be flashing (the soak and strong indicators). If they aren’t keep repeating the above procedure until they do.
    Once the two outer lights are flashing, push the programme select button once more, the left hand (soak) light should now go off. With just the strong indicator flashing, switch the machine off by the on/off switch.
    Remember to keep the door open all the time while doing this. Once you’ve done all that, it should be OK and you can check using the soak programme for quickness.
    Please let us know how you get on.
