diplomat dishwasher 8322 7 flash fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat dishwasher 8322 7 flash fault
  • #30898
    grayz4
    fault is 7 flashes then pause , beeping and rinse light comes on , seems to fill a bit then fault occurs it will drain away if left a few more seconds. any ideas anyone please.
    #228853
    aqualectric
    Re: diplomat dishwasher 8322 7 flash fault
    Error 7 = Flow meter failure.
    Unplug machine, remove left side panel and the flow meter is the small PCB with an edge connector plug and wiring going to it. Pull off the plug , clean the edge contacts and refit plug. Test for function.
    Power off, plug out before any inspection. :plug:
    Steve.
    #228854
    grayz4
    hi, I take it you mean pulling out the dishwasher from unit and get access from exterior panel . Is this a job that I may be able to fix without the need for an engineer
