Diplomat dishwasher – ACA9102 – Not programming
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat dishwasher – ACA9102 – Not programming
  • #68059
    grooster
    I’ve just been out to look at a Diplomat slimline dishwasher ACA9102 – its the chinese made piece of cr*p version.
    The machine powers on but you cannot move the programme indicator on to any programme. If you keep the button pressed as you turn it off if makes a slight beep light it should when it advances from one programme to the next when selecting it.
    Customer said that when he got to the machine when it failed, all the lights where flashing but now its just dead.
    Ive had this fault few times recently but have normally told the customer quite rightly that the machine is dog and its probably not worth it, presuming it to be a PCB fault.
    Unfortunately for me, the customer is moving house in a few months and wants it fixing no matter what the cost.
    Has anybody had this fault and fixed it?
    Any help would be appreciated.
    Many thanks, as per usual guys
    Nick
    #369470
    A1engineer
    Re: Diplomat dishwasher – ACA9102 – Not programming
    insulation fault on wash motor.
    might have water in base you might be able to fix leak(if there is one) and dry out motor, but chances are itll need replaced.
    #369471
    grooster
    No, i checked the base for leaks and it was bone dry. First thing i always check with these machines, with the over soaping problem and the centre shaft unscrewing itself, I even meggered the machine and it showed up as acceptable.
    #369472
    A1engineer
    will probs still be a motor fault, ive done loads of these with those symptoms.
    #369473
    grooster
    Cheers for that, think i’ll go armed with a motor as well when I go back. You dont know the part number for the motor do you. The only place I can see it at is connect and they dont show part numbers. Its not listed at masterpart and qualtex under this model number.
    Thanks again
    nick
    #369474
    A1engineer
    motor part number – 012G9380538
    i have emailed you the service manual to the email address linked to your website.
    HTH
    Kevin
    #369475
    grooster
    Cheers for all your help Kevin.
    Youve actually, inadvertently, pointed something really important out to me. My email address linked the my website is wrong.
    Ill get on to it straight away.
    Is there any chance you could resend it to me pal.
    appointments@arrow-electric.co.uk.
    I really appreciate your help Kevin.
    Regards
    Nick
    #369476
    A1engineer
    Have resent to that email address.
    Kevin
