Please can any one help me. Ihave resentlymoved into a new house and my dishwasher keeps showing up a F1 fault, does any one know what this means and how do i rectify it.
Hiya,
An NTC is a negative temperature coefficient thermistor.
The fault code on your machine indicates that there is a problem in this area of your machine. Fault codes are only a likely indication of the problem and I’d recommend an engineer check out the machine as you could end up throwing parts at it trying to cure the fault.
Hope this is of some help.
DP
THanks DP,
Do you know of any Engineers in the Liverpool area that can fix this problem. I have had 1 person out and he didnt seem to know what he was doing and charged me £15 for a 2 minute job and pressing some of the buttons. The problem is intermitent and it so happened it worked when he tried it now I am back to were I started.
