diplomat dishwasher adp 8630
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat dishwasher adp 8630
  • #40793
    taffg
    i had a problem with start/stop button on the machine. i removed the pcb board and after cleaning the small switch i got continuity and everything was good. put everything back together but when i turn the machine on the salt level and rinse aid indicators are lit and the program indicator stays on “no heat program”. I cannot change the programms using the button, but the stop start button is working fine. The dishwasher will work ok on the no heat program.
    ive just filled the rinse aid dispenser with water and the rinse aid indicator has gone out!. Tried the same with the salt chamber no joy.
    Any ideas???
    #267579
    Re: diplomat dishwasher adp 8630
    Model number not recognised – please re-check.
    taffg
    hi penguin 45,
    i can confirm the model number as a diplomat adp 8630 ser no 203313 which was bought from howdens approx 15 months ago
    #267581
    Yup, it’s the Beko-built one. Regret I’m not familiar with the machine. Others may be able to advise.
    karv
    these maybe silliy ideas but u never know
    is the button stuck had a few where the decor door has been screwed to tight and is clamping the facia and holding down the button so u can,t push the button 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
    have u held down the start button untill the light has gone out , and then try to change programe , these things can get very glitchey with power cuts it seems and the programe then gets stuck.
    also i think try and hold down the start button for some secs untill the light flashes and close the door and it will drain , this will abort any programe that is running , i think . then once it finished try to pick new programme.
    I would say if the start button light is off and the programe light is still on rinse and u can here the little click as u push the p button down i would guess for a faulty module or display pcb but that would be a guess.
    #267583
    taffg
    many thanks penguin45 and karv
    have tried the trick suggested to no avail, have re-checked the switch on the pcb and its definately working correctly so something else in the board must be kaput, time for on line parts search, for new pcb and marigolds!!
    many thanks for all your help
    regards
    tony.
