Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat Dishwasher ADP8224
- This topic has 19 replies, 4 voices, and was last updated 18 years, 11 months ago by
knot.
May 7, 2007 at 6:01 pm #27176
knot
ParticipantHi im getting an E7 message for the above model, the water drains at the start of the cycle,and then the error comes up, any help would be great thanks
May 7, 2007 at 6:10 pm #212944Penguin45
ParticipantRe: Diplomat Dishwasher ADP8224
http://www.ukwhitegoods.co.uk/modules.p … t=assuming
Same problem, same solution.
Penguin45.May 7, 2007 at 6:25 pm #212945knot
hi, thanks for the really quick response!
i am not sure but you may have sent the wrong link, our problem is not flashing lights. we actually have no lights on the control panelMay 7, 2007 at 6:37 pm #212946Penguin45
How have you got E7 then?
May 7, 2007 at 6:44 pm #212947knot
hi, on the display screen there are no lights. it just shows the programme number you have selected in black writing. the e7 error message comes up like that, in black writing but there are no flashing lights.
hope this makes sense!sorry if im being a bit slow!
May 7, 2007 at 6:46 pm #212948clivejameson
Is that a Smeg built model Chris?
May 7, 2007 at 6:48 pm #212949Penguin45
Yeah, got it now – it’s the three button LCD display one. E7 is no drop in water level detected in the time allowed, ie it’s probably blocked.
Sorry about the confusion,
Penguin45.May 7, 2007 at 7:38 pm #212950knot
No problem, so E7 is a blockage with the water coming in to the machine? Thanks again
The machine seems to draining ok ie no water in the bottom of the machineMay 7, 2007 at 9:15 pm #212951Penguin45
No. The water level control system works on an air pressure system. During drain, the computer allows a fixed amount of time for the system to depressurise and release the pressure switch, in order to decide that is is empty and so progress to the next stage of the wash. Normally, a blockage in the drain system (pump, hoses or drain coupling) would keep the water in the machine, until the computer times out and brings up the error. However, a build-up of sludgey deposits in the internal pipework of the machine can hold the system pressurised, regardless of whether the water pumps out or not……… Tricky one to resolve – disassembly of the water matrix on the side of the machine may well be involved to allow access to the pipework and pressure system for cleaning.
Power off if you’re going to give it a go.
Penguin45.May 7, 2007 at 11:41 pm #212952knot
Thanks Penquin reply is very much appreciated,i dont suppose there are any cleaners that could remove these deposits or is that just wishfull thinking? Thanks again
May 7, 2007 at 11:48 pm #212953kwatt
KeymasterRe: Diplomat Dishwasher ADP8224
We wish knot, that would make our lives so much easier!
No, the only cleaner that works is hot water, a bottle brush and a bit of effort to clear the fill matrix.
As P says though, it can be caused by blockages elsewhere but the fill matrix is the main suspect with this sort of thing. If it’s really bad it will likely need replaced.
May 7, 2007 at 11:48 pm #212954Penguin45
Hi Knot,
No chance I’m afraid……… This is worth a read:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=102You’ll realise from my initial post that SMEG use 2 completely seperate sets of fault codes 😳 . This may help, if it doesn’t a strip down and clean out is the only proper way to proceed.
May 7, 2007 at 11:53 pm #212955kwatt
Penguin45 wrote:You’ll realise from my initial post that SMEG use 2 completely seperate sets of fault codes
Keep counting.
I’m the idiot that’s been trying to put it all into an intelligible manual! 😕
May 7, 2007 at 11:58 pm #212956Penguin45
The SMEG ones are easy enough – it’s working out the “badge” jobs that does my head in………
:p45:
May 8, 2007 at 12:15 am #212957knot
Thanks for all your help, most helpful
