diplomat dishwasher adp8242 lights 2&3 on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries diplomat dishwasher adp8242 lights 2&3 on
  • #20923
    SDR
    can anyone give me any ideas, i have a diplomat dishwasher fault lights 2 & 3 on, will start up pump out and stop 3 times then lights come on, ive checked, fill valve , no visable blockages, no water leaks to base. tried new drain pump as it was getting very hot , still no different.
    #188826
    Re: diplomat dishwasher adp8242 lights 2&3 on
    It’s a SMEG – no drain in the time allowed. If it is actually draining, check the water level control for blockages.
    SDR
    checked for blockages , no signs of any it wont fill at all it just starts to pump out then stops after a few mins. any other ideas??
    #188828
    Water level control……… It’s a famous fault………
    SDR
    new pressure switch then, wouldnt be the anti flood device ??
    #188830
    Strip and clean everything you can get at, especially the tube from the sump to the fill matrix. Haven’t need a pressure switch yet………
