Diplomat Dishwasher ADP8332
  • #52886
    mjhservices
    Fills for 10 seconds and then F7. Checked the flow meter and the little circuit board is open circuit (what reading should I get from this?)
    Can you buy this small part without the whole plastic tank?
    Regards Mark
    #313508
    Washman
    Re: Diplomat Dishwasher ADP8332
    The small pcb by the flow meter is just a magnetic swich. If its playing up tighten up the plug. If still playing up you need to replace the “can-measuring ” as its called on parts diagram
    Mike
    #313509
    mjhservices
    Thanks for the info although I did tighten up the plug etc and it did not work.
    What does this part do?
    Regards Mark
    #313510
    Waterwheel in the chamber has a magnet in it. The water flow spins the wheel, moving the magnet past the reed switch on the pcb, which will then open and close. PCB counts these as part of fill monitoring.
