diplomat dishwasher E2 error code
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat dishwasher E2 error code
  • #7087
    Our dishwasher was coming up with the non listed E2 error code.
    We took the plate off in the base and used a bottle brush down the outlet pipe. This seemed to release a lot of accumulated dirt and grease and the dishwasher has worked ever since. 😆
    #121316
    Dave_Conway
    Re: diplomat dishwasher E2 error code
    Well done Peter 😀
    E2 is or can be a notorious fault to detect, ranging from a simple blockage such as you discovered right up the failure of the main PCB control unit.
    Early Xmas gift for you to have a nice easy one 😉
    #121317
    Our dishwasher was coming up with the E5 error code. Could you please advice us.
    #121318
    Dave_Conway
    E5 means that it isn’t filling with water, the only checks you can do are:
    Make sure the supply tap is turned on and there is water at the tap also check the supply hose isn’t kinked.
    Apart from that, you’ll need an engineer as it could be a number of other internal components at fault.
