Diplomat dishwasher Eco light on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat dishwasher Eco light on
  • #20294
    geoffmackay
    Got a Diplomat ADP 8242 dishwasher s/no 26134 0103 with eco red light stuck on and wont re program. Assume its module failure but wouldn’t mind a second opinion.
    Geoff
    #186499
    Re: Diplomat dishwasher Eco light on
    Module probably – have you tried the reset proceure? Also check dispenser solenoid – wierd things can be caused by it.
    geoffmackay
    Reset?? how do you do it? Only two buttons on panel, main on off switch and program button which refises to do anything.
    #186501
    It’s a SMEG…….
    Power off. Switch on + press the programme button four times very quickly. LEDs 1+5 should be lit. Switch off, pause, switch on and run the pre-wash cycle.
    geoffmackay
    Tried to reset it this morning with no joy. Do you have the part number for the module Chris?
    #186503
    Geoff, you’ll have a rather large email in a few minutes. 😉
    scots
    Hi kevin, I have had similar prob on Friday, 2 lights stuck on, tried everything to reset it to no avail, assumed it to be a board fault. can you help
    Brian
    #186505
    Mail, Brian.
    scots
    Cheers chris 😀
    #186507
    allan73
    I’m resurrecting this old thread because I had a Smeg DW with a similar fault on christmas eve. Original call was to door catch locked shut and customer had to force open. Facia panel was found to be broke where door catch assy fits in and replaced along with catch itself.
    Now m/c won’t start and light 4 just flashes constantly as soon as switched on. I will try to reset as suggested on this old thread when I get back into work, other than that any thoughts guys ?
