Re: DIPLOMAT DISHWASHER FAULT
thanks for info sheet, which is a very good guide.
as this appliance is my own, I have this morning stripped it down completely. My wife is a regular user of descaler so I was sure that the problem was not due to blockages.
as I discovered all oultets, water matrix, sump valve etc are clean as a whistle.
up on running unit without case you can activate anti flood micro switch and it works fine.
I have checked pressure pipes and they appear ok
I have decreased inlet water pressure also
but still it fills/pumps out and then finally pumps matrix empty
any other thoughts most welcome
Graham
