Checked through the fault code thread and there are some listed for Diplomat but not the one I saw today, model ADP8242. 4th & 5th LEDs were flashing and the machine was just pumping out continuously. On this machine with the front chassis panel removed you can see most of the plastic base and there is no evidence of leaks. Customer says the problem appeared after they had put the machine on a cleaning run with some Tesco liquid dishwasher cleaner.
