Hi can anyone help I have just installed the above dishwasher & put it through its first wash which seemed to be going fine until it stopped then started to BEEP & the error cade says F2 I have checked filter & water seems to have drained out ok. I have tried the phone number but engaged all the time
Hi Dave it is a brand new machine & this was its first wash by the way it has washed the dishes fine they are clean & sparkling its just that this F2 fault is flashing & the beeping sound & the start button is flashing.
OK, silly one here. Has it drained the water away?
If not, check the spigot under the sink isn’t plugged.
Amazing the number of new machines I go to have the drain hose fixed to a plugged spigot 😛
Its Ok I have sorted the problem thanks for all the help it turns out I had the pipe too far down drain & laying in small amount of water but enough to cause the fault, but all sorted now Thanks once again
