Diplomat Dishwasher or Brandt bdw 045
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat Dishwasher or Brandt bdw 045
  • #29580
    CLOGGER
    hi,
    I Have a problem with this DW
    Machine is none responsive. It is displaying 3 light on and 1 flashing out of 5 lights. The order is:
    1 off
    2 on
    3 on
    4 on
    5 flashing
    any ideas! 😕
    #223705
    Re: Diplomat Dishwasher or Brandt bdw 045
    SMEG built machine – no drain detected in the time allowed.
    CLOGGER
    Thanks for the advice ,I’ll give it a try 🙂
    #223707
    CLOGGER
    hi again. I have Checked the pressure chamber, pipe, pressure switch, pump both electrically and physically but I Cant Find any problems or blockages. If I empty the machine of water it will refill but nothing else. I cant reset the control panel. Is this 14 month old machine a right pile s*** or am I loosing it? :taz:
    #223708
    clivejameson
    CLOGGER wrote:hi again. I have Checked the pressure chamber, pipe, pressure switch, pump both electrically and physically but I Cant Find any problems or blockages. If I empty the machine of water it will refill but nothing else. I cant reset the control panel. Is this 14 month old machine a right pile s*** or am I loosing it? :taz:
    Neither i would suggest 😆
    It’s not unknown for these to give a fault indication then lock out even when no fault is apparent, or even give a spurious fault indication for that matter…all you can do is check the obvious (earth faults etc), ohhh and the dispenser solenoid…then replace the pcb 😉
